MIBs for Cisco 10000-PRE4
May 21st, 2009
Hi sir,
I'm trying to locate the SNMP MIBs for Cisco 10000-PRE4 with IOS 12.2(33)SB5 and UPTO 8K SUBSCRIBERS W/3DES feature set.
It's not available. Only the MIBs for 10000-PRE3 with same IOS version & feature set is available.
Can I use the 10000-PRE3 MIBs to manage the 10000-PRE4? Are they the same?
Please advise.
Thank you.
Lim TS
limtohsoon Thu, 05/21/2009 - 21:50
Hi Joe,
Here you go...
Cisco IOS Software, 10000 Software (C10K4-K91P11-M), Version 12.2(33)SB5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 04-Apr-09 11:03 by prod_rel_team
ROM: System Bootstrap, Version 12.2(20071113:194412) [shalpin-rom-1_2 101], DEVELOPMENT SOFTWARE
C10K-PRE4 uptime is 4 days, 3 hours, 32 minutes
Uptime for this control processor is 4 days, 3 hours, 32 minutes
System image file is "bootflash:/c10k4-k91p11-mz.122-33.SB5.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco C10008 (PRE4-RP) processor (revision V02 ) with 2588671K/163839K bytes of memory.
Processor board ID NWG130204TA
SB-1 CPU at 800Mhz, Implementation 0x410, Rev 5.0, 512KB L2 Cache
Backplane version 1.0, 8 slot
Last reset from power-on
PXF processor tmc0 is running.
PXF processor tmc1 is running.
PXF processor tmc2 is running.
PXF processor tmc3 is running.
1 FastEthernet interface
5 Gigabit Ethernet interfaces
7039K bytes of non-volatile configuration memory.
126000K bytes of ATA compact flash in bootflash (Sector size 512 bytes).
1000944K bytes of ATA compact flash in disk0 (Sector size 512 bytes).
Standby is up
Standby has 2752512K bytes of memory
Thank you.
Lim TS
