Quick question re Access-lists Outside & Inside
May 22nd, 2009
New to networking so just need someone to confirm this please regarding ASA firwall. If I have created an access-list on the outside interface which allows an outside device to to create a connection to a specific ip address and port on the inside do I also need to create an entry on the inside interface access-list to allow the return traffic?
Many Thanks
Darren
handsy Fri, 05/22/2009 - 02:19
Short answer: No you don't
Long answer: Cisco ASA firewalls are stateful, therefore when a connection is built in 1 direction, the other direction is automatically allowed. Also, a connection iniating from inside (high security interface) to outside (low security) is automatically allowed through so long as an accompanying NAT rule is in place.
Hope this helps :)
Please rate posts if they help you.
