05-22-2009 12:57 AM - edited 03-15-2019 06:08 PM
i'm experiencing confusing problems with our isdn bri connection in italy. the main number ends with '60'. our did range is '600' until '619'. But on incoming calls, the called party ends always with '60'. And the confusing thing is, the gateway receives the missing digit(s) after the ISDN 'disconnect' message (sending-complete)
the interface config
isdn switch-type basic-net3
isdn overlap-receiving t302 20000
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn outgoing-voice info-transfer-capability 3.1kHz-audio
isdn static-tei 0
trunk-group 1
debug isdn q931 for an incoming call
to DID '607'
May 22 08:36:48.111: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x5C
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2183, '4713064'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '47159860'
May 22 08:36:48.119: ISDN BR0/0/1 Q931: TX -> SETUP_ACK pd = 8 callref = 0xDC
Channel ID i = 0x89
Exclusive, B1
May 22 08:36:48.151: ISDN BR0/0/1 Q931: TX -> DISCONNECT pd = 8 callref = 0xDC
Cause i = 0x8090 - Normal call clearing
BRI-VG1#
May 22 08:36:48.195: ISDN BR0/0/1 Q931: RX <- INFORMATION pd = 8 callref = 0x5C
Sending Complete
Called Party Number i = 0xA1, '7'
May 22 08:36:48.319: ISDN BR0/0/1 Q931: RX <- RELEASE pd = 8 callref = 0x5C
May 22 08:36:48.323: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xDC
05-22-2009 01:25 AM
i resolved the problem:
i configured 'isdn overlap-receiving' instead of 'isdn overlap-receiving t302' on the interface.
but what is the difference between these both commands?
05-22-2009 04:40 AM
Max,
Hopefully this doc will help explain but the T302 is the interdigit timout. After the T302 part of the command you can also add a value in ms if you wish to remove it from the default which is 10secs, which can be a little long in cases
http://www.cisco.com/application/pdf/paws/23382/isdn_overlap_prob.pdf
Hope this helps
Paul
05-22-2009 08:51 AM
When you receive this message:
BRI-VG1#
Sending Complete
it does NOT mean that sending complete is BEFORE the called digit. That is just the way it is printed.
It means that you have received the last digit.
