Site to Site vpn UC 500
May 22nd, 2009
I need to configure site to site vpn using UC 500 , in one side, i have static ip the other end it is dynamic , what is best way to set up a connection using this scenario , EZVPN_GROUP_1 is configured , clients can access the system, but I cannot configure the two UC for communicating each other .
Please advise me what way I can connect these systems.
Suraj kumar
suraj12345 Fri, 05/22/2009 - 07:11
UC 520 in the main site
When I configure using as per the doc
My main site UC is having static ip in WANfor ex xxx.xxx.xxx.xxxx 255.255.255.248
Lan ip is 172.32.0.0 /24
Well the other site
Have Dyanmic ip in wan site
Lan side 192.168.10.0 /24
When I ceate the isakmp policy in the main router having static IP
Crypto isakmp policy 1
Encr 3des
Hash md5
Authentication pre-share
Group2
Crypto isakmp key sbcs address ( the remote site ip is dynamic I have dyndnshostname , but it is not accepting)
What can I do here?
Please advise.
suraj12345 Fri, 05/22/2009 - 10:15
Cisco (config)#Crypto isakmp key sbcs address aaa.dyndns.org
% Invalid input detected at '^' marker.
When I try a host name instead of ip address  the system says invalid input .The host name which I posted is not  a real hostname (just an example).If I put my real hostname also the result is the same.
Steven DiStefano Fri, 05/22/2009 - 10:45
  • Blue, 1500 points or more
Try Hostname parameter instead?
SBCS-Mobility(config)#crypto isakmp key ?
  0     Specifies an UNENCRYPTED password will follow
  6     Specifies an ENCRYPTED password will follow
  WORD  The UNENCRYPTED (cleartext) user password
SBCS-Mobility(config)#crypto isakmp key key123 ?
  address   define shared key with IP address
  hostname  define shared key with hostname
suraj12345 Fri, 05/22/2009 - 12:11
CISCO(config)#crypto map multisite 1 ipsec-isakmp
% NOTE: This new crypto map will remain disabled until a peer
        and a valid access list have been configured.
CISCO(config-crypto-map)#
Please advise me which acl i have to define her
