Sip trunk
Driss BENATTOU
Level 4
Level 4
I want to know the archetecture used to configure a SIP trunk between CCM and softswitch.
It's CCM --(H323)--> Gateway --(SIP)--> Softswitch
Or CCM --> Softswitch
You can use:
CCM - h323 or sip trunk - GW(CUBE) - SIP trunk - softswitch
CCM - SIP turnk - softswitch probably not as CCM dosen't support any form of authenication on SIP trunks.
hattingh
As per previous answer, use CUBE (an ABC) in between to do the security demarc and protocol conversion.
Config at
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml
CH
Thanks for your help
