ASA security bundle starting point
May 22nd, 2009
Hi,all
I have a box pack ASA 5510 with security-plus license.My question is what is my step when i install the asa? i have to run or add any code for security licenseces or i have only install asa as it is?
handsy Fri, 05/22/2009 - 04:42
No, it'll already be done for you. The licence will be pre-installed on the ASA.
Note: you need at least ASA software 7.1x (I think) before you can see your 2 x 1000/100/10 interfaces that come with the Sec+ licence.
srue Fri, 05/22/2009 - 04:49
  • Blue, 1500 points or more
you can verify the license once you have the ASA powered up by issuing the command "show version".
also, ASA doesn't run IOS.
