IPCCX Script: Writing to XML document
May 22nd, 2009
Hi all,
I was hoping someone can help me with an issue I have with writing and reading to and from a XML document. I have racked my brains and cant get it working.
Essentially, I have a script which takes in user input for a pin. Once it does that, it checks the "emergency" flag in an XML document. I have created the file and the xml doc but when it comes to getting information from it, I get the error from the reactive debug as follows:
emergencyflagtemplate.xml (The system cannot find the file specified); nested exception is: java.io.FileNotFoundException: emergencyflagtemplate.xml (The system cannot find the file specified).
I have explicitely coded where the file is as well and still the same issue.
I followed the sample scripts in CCO called state_Check and state_Update and still no joy.
If someone can give me a pointer in the right direction, that would be great.
Stew
