css 11501 redirection
May 22nd, 2009
Can the loadbalancer provide type 301 (permanent) redirects instead of 302's which are temporary.
Also can a redirect retain a variable identifier in a rewrite rule eg :-
http://www.test.co.uk/search/story/?story_id=2234160 to Redirect to new format: http://www.test.co.uk/article.aspx?storycode=2234160
sachinga.hcl Fri, 05/29/2009 - 12:15
the CSS does not have this option for providing type 301 (permanent) redirects instead of 302's which are temporary
CSS only supports 302 redirects.
There is no support for 301 redirects.
Use the below mentioned URL for configuring redirection.
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a00801de8d6.shtml
If you need is replace the http with https, you can use the urlrewrite function.
A quick search in the configuration guide will show you how to use this command.
Configuring Persistence, Remapping, and Redirection on the CSS 11000 and CSS 11500 - Ciscowiki
http://supportwiki.cisco.com/ViewWiki/index.php/Configuring_Persistence%2C_Remapping%2C_and_Redirection_on_the_CSS_11000_and_CSS_11500
Configuring Stickiness on a Cisco CSS 11xxx Using HTTP Redirects - Ciscowiki
http://supportwiki.cisco.com/ViewWiki/index.php/Configuring_Stickiness_on_a_Cisco_CSS_11xxx_Using_HTTP_Redirects
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_tech_note09186a00801c65b5.shtml#ex1
Kindly find full range of configuration examples on CSS here :
Cisco CSS 11500 Series Content Services Switches
Configuration Examples and TechNotes
http://www.cisco.com/en/US/products/hw/contnetw/ps792/prod_configuration_examples_list.html
http://supportwiki.cisco.com/ViewWiki/index.php/Category:Cisco_CSS_11500_Series_Content_Services_Switches
Kindly see URL given below for my other articles
http://boardreader.com/fp/Cisco_Systems_Networking_Profe_309110/Application_Networking_543840.html#hot_threads
If possible plz rate so that I can be helpful to other people also as it will enhance my credibility.
sachin garg
