3548xl Speed/Duplex Mismatch Question
May 22nd, 2009
Is there any way from the console of the 3548xl to tell if the device connected to a particular port is speed/duplex mismatched?
All the ports on the switch are set to 100/Full and I want to ensure all the desktops are as well.
Collin Clark Fri, 05/22/2009 - 06:23
CRC errors are usually an indication of a mismatch.
<b><font size="2" color="blue"> show interface | i CRC</font></b>
You can also see what devices are running at half duplex.
<b><font size="2" color="blue">show interface | i half</font></b>
Hope that helps.
gobigblue Fri, 05/22/2009 - 07:32
Are there any free windows based tools that lets you see what IP's are on what port?
