Unframed E1on AS5350XM
Answered Question
May 22nd, 2009
In order to run unframed E1 we need to use either one of these two cards:
AS53-4CE1+ , AS53-8CE1+
However, according to the feature navigator these cards are supported
only on the AS5300.
Are there any alternatives for the AS5350XM or the AS5400 ?
Best regards,Pan
Correct Answer by paolo bevilacqua about 7 years 12 months ago
Correct, the 5350 and 5400 are pure Universal Access Servers to be used together with an external router to terminate serial or other type of WAN links.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sat, 05/23/2009 - 12:44
  • Hall of Fame,
    Founding Member
What do you need unframed for ? Voice circuits are always and exclusively framed.
The 5300 reference is a mistake.
paolo bevilacqua Mon, 05/25/2009 - 09:51
  • Hall of Fame,
    Founding Member
I think you do not understand the nature of an AX5xxx.
The E1 ports are made to be connected to PSTN in channelized mode, where a maximum of 30 channels can be used for voice, data, modem and fax.
If you need instead to connect to an unframed daya circuit, you will use instead the serial ports available on some AS5xxx with an interface converter, or use another router with native E1 interface.
Hope that makes it clear.
7pliapis Mon, 05/25/2009 - 11:30
What I understand is that there are no available parts that
-combine the functionality of the CE1+ cards (i.e x E1/PRI Plus High Speed Serial)
-or provide just High Speed Serials
Regards,Pan
Correct Answer
paolo bevilacqua Tue, 05/26/2009 - 09:42
  • Hall of Fame,
    Founding Member
7pliapis Wed, 05/27/2009 - 00:55
Thank you for your assistance and clarifications.
Best Regards,Pan
paolo bevilacqua Wed, 05/27/2009 - 01:11
  • Hall of Fame,
    Founding Member
Thank you for the nice rating and good luck!
