Clarification on trunking on this 'cascaded' switch
Answered Question
May 22nd, 2009
Imagine I have the following:
Switch1 (all ports on Vlan1)
fa0/10 ---connected to-----fa0/10Switch2
Switch2 (all ports on Vlan2)
If I want hosts from Vlan2 to communicate with switch1 Vlan1 hosts, I would need to do:
switch1
int fa0/10
switchport mode trunk
switchport allowed vlan 2
and do the same on switch2.
Is that correct?
Correct Answer by John Blakley about 8 years 4 days ago
That's correct, but you'd need to create a vlan 2 on the vlan 1 switch and vice versa. The vlan's need to match on both switches. Then configure your int fa0/10 like your example.
You *may* need to change your line to allow vlan 1 also (but it's native by default, so you may not):
switchport allowed vlan add 1,2
HTH,
John
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Fri, 05/22/2009 - 08:14
  • Purple, 4500 points or more
HTH,
John
Leo Laohoo Sun, 05/24/2009 - 14:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
John's right. Aside from creating the VLAN 2 SVI, if your switch is the 2900/3500, 2950/3550, X4013+, you need to create VLAN 2 on the VLAN database.
