NHRP on 6500 VSS ????
May 22nd, 2009
  • Bronze, 100 points or more
We are trying to set up some isolated virtual networks using VRF-lite and mGRE, and ran into a problem. It looks like our brand new 6500 VSS system doesn't support NHRP. We are running 12.2(22)SXI1 on SUP720-10GEs. Without NHRP it looks like we need to make a bunch of point-to-point tunnels rather than a multi-point GRE tunnel :( . Am I missing something ??? Any input would be greatly appreciated.
Dave
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Sun, 05/24/2009 - 04:46
  • Hall of Fame,
    Founding Member
Hello Dave,
according to feature navigator tool
www.cisco.com/go/fn
DMVPN phase2 is supported in your hardware but only with Advanced Enterprise or Advanced IP services IOS versions
ADV ENT SERV SSH LAN ONLY s72033-adventerprisek9-mz.122-33.SXI1.bin 1024 1024
ADV IP SERV SSH LAN ONLY s72033-advipservicesk9-mz.122-33.SXI1.bin 1024 512
ADVANCED ENTERPRISE SERVICES SSH s72033-adventerprisek9_wan-mz.122-33.SXI1.bin 1024 1024
ADVANCED IP SERVICES SSH s72033-advipservicesk9_wan-mz.122-33.SXI1.bin 1024 1024
So you may need a feature set upgrade.
Hope to help
Giuseppe
