VPN Concentrator - How to assign a different DHCP pool to each group?
May 22nd, 2009
I'm using a VPN concentrator and running into some trouble. I would like to be able to assign a different DHCP pool to each group. They can be within the same /24, if necessary, but I need to be able to control which smaller group they are put into. Ideally I would like the following:
GROUP1: 192.168.1.192-223
GROUP2: 192.168.1.224-239
GROUP3: 192.168.1.240-255
Or something to that effect.
I have done the following:
+Selected the "use dhcp" and "use address pools" checkboxes.
+Created two separate DHCP pools (similar to those above)
+Gone in each Group configuration and set "DHCP Network Scope" to the first address in it's respective pool.
For some reason, though, addresses are always given out from a single pool. If I have two users connect, each to a different group, they will both receive addresses from the top pool in the list.
Any insight would be a huge help!
Overall Rating: 5 (1 ratings)
Farrukh Haroon Sun, 05/24/2009 - 05:42
  • Red, 2250 points or more
How is your DHCP server configured? Do you have any Super scopes? What platform is it?
Farrukh
tylerlucas Wed, 05/27/2009 - 14:39
We decided that instead of messing with this we would just use our 3825 router which is closer to the server farm.
Thank you for your help though!
