AIR-AP1231G-A-K9, Multiple BVI interfaces?
May 22nd, 2009
Is it possible to create multiple BVI interfaces and assign each of them IP addresses of different VLANs?
I have this AP and it's broadcasting 2 SSIDs (1 on VLAN1 and another on VLAN17). They work fine. The BVI 1 has IP 10.0.1.100/24 and BVI 17 has 172.17.252.100/16. The switch is 3750 and vlan1 interface has IP 10.0.1.10/24 and vlan17 interface has IP 172.17.254.10/16. However only BVI is pingable but not BVI 17. Can I use BVI 17 interface and its IP for management? Thanks!
weterry Fri, 05/22/2009 - 20:06
  • Silver, 250 points or more
If you have vlan 1 and 17 working, then I assume you have subinterfaces for both the radio and the fast ethernet port? And each sub-interface is correctly mapped to a bridge-group of the BVI?
Maybe need to add "bridge 17 route ip"?
Post your config please?
Difan Zhao Mon, 05/25/2009 - 07:55
Here is the config. I can't put "bridge 17 route ip" on. It says that route ip is only allowed on bridge group 1. Thanks!
Building configuration...
Current configuration : 2090 bytes
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$.CHB$zRbJ5fqZ7HG817zSv1P0k.
ip subnet-zero
no aaa new-model
dot11 vlan-name GN vlan 17
dot11 vlan-name Native vlan 1
dot11 ssid SSID_VLAN1
vlan 1
authentication open
mbssid guest-mode
dot11 ssid SSID_VLAN17
vlan 17
authentication open
mbssid guest-mode
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid SSID_VLAN1
ssid SSID_VLAN17
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.17
encapsulation dot1Q 17
no ip route-cache
bridge-group 17
bridge-group 17 subscriber-loop-control
bridge-group 17 block-unknown-source
no bridge-group 17 source-learning
no bridge-group 17 unicast-flooding
bridge-group 17 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.17
no ip route-cache
bridge-group 17
interface BVI1
ip address 10.0.1.100 255.255.255.0
no ip route-cache
interface BVI17
ip address 172.17.252.100 255.255.0.0
no ip route-cache
ip default-gateway 10.0.1.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
