Call drop problem
May 23rd, 2009
Kindly do my favor.
I'm doing a test :-
There are two cisco routers with BPL EPABX. VWIC2-2 MFT-E1/T1 card and intalled in router and DTMF E1 card is installed in EPABX. In this time call is through from one console or extention numbers connected with EPABX to another console of EPABX in both sides.There are different extention numbers connected with EPABXs.
Now i want to call from any extention number of one side EPABX to other extention number of anothor EPABX directely with out console call drop, but we want also an option of console to console to call also in case of user does not know another side entention number.
Which type configuration i need to change in dial-peer of router side.??
One router:-
dial-peer voice 1 pots
destination-pattern 100
port 0/2/0:1
forward digits all
dial-peer voice 2 voip
destination-pattern 200
sesstion taraget ipv4:10.10.10.1
Two router:-
port 0/2/0:1
forward-digits all
destination pattern 100
sesstion target ipv4:10.10.10.2
paolo bevilacqua Sat, 05/23/2009 - 11:41
  • Hall of Fame,
    Founding Member
If the call drops, likely the called number is wrong, so you have to explain how your numbers are made.
siddindia Sun, 05/24/2009 - 05:05
Dear friend,
There is no problem in this time.call is through in both side at console of EPABX. But i want to call from one extention of one side router to another side extention directely with by pass of console.
Example:-
Router A side:- extention no of EPABX-111,...etc, console no of EPABX-100.
Router-B side:- extention no of EPABX-222,....etc,console no of EPABX-200.
Call is through from 111 and 100 router A side to 200 router B side and same is from router B side.
I want to call from 111 or 100 directly 222 and same other side also.The previous option will also be exists.
Kindly help me.
paolo bevilacqua Sun, 05/24/2009 - 10:11
  • Hall of Fame,
    Founding Member
Hi, if you have the same extensions numbers on both sites you will need to use a prefix digit for example site A will be 3xxx and site B 4xxx. The details depends from the numbers you have currently in use and you configure voip and pots DP with that destination-pattern.
Please remember to rate useful posts with the scrollbox below.
