attack to GRE tunnel
May 23rd, 2009
Dear All
I have gre tunnel between some routers
is it possible in mid of this tunnel some one try to sniff the data across tunnel?
please mention with a document
thank you all
andrew.prince@m... Sat, 05/23/2009 - 08:38
  • Green, 3000 points or more
Is the GRE tunnel completely inside your network, or does it traverse the internet or any other network not controlled by you?
hani-molani Sat, 05/23/2009 - 08:56
HI
the source tunnel is in my network and the destination of tunnel is passing through internet, but the tunnel has its own key and using hash and also AES encryption.
