Error while renewing the certificate in SSLM
May 23rd, 2009
While renewing the certificate on SSLM I am getting the following error
% failed to parse or verify imported certificate.
I am able to upload root certificate successfully.
I am sure that I renewed the certificate using the correct parameters.
Please advise
Jithesh
sachinga.hcl Sun, 05/24/2009 - 02:32
  • Silver, 250 points or more
Hi Jithesh,
This error can occur when you install the identity certificate and do not have the correct intermediate or root CA certificate authenticated with the associated trustpoint. You must remove and reauthenticate with the correct intermediate or root CA certificate. Contact your 3rd party vendor in order to verify that you received the correct CA certificate.
Cheers!!
Sachin
