WiSM IOS upgrade
May 23rd, 2009
Hi all,
In order to support the newer n radios we are upgrading the WiSM IOS to 5.2.157.0 from 4.2.176.0.If someone could advice us the caveats that we might come across, it would be most appreciated.
cheers,
Janesha
Overall Rating: 4 (3 ratings)
Robert Rowland III Sun, 05/24/2009 - 04:48
Skip 5.2.157, go to 5.2.178. `157 has/had many bugs.
Some of the RRM power level stuff has changed.
AP GROUPS have changed ... I like the new way.
If you define DHCP on the WLAN vs interface you may have problems.
L2 Peer to peer blocking has changed for better.
You can - so I am told - modify PSKs with WCS now.
Don't know the size/layout of your network so some may not impact you , but just skip to .178
Check your router code level to make sure it is "new" enough.
janesh_abey Sun, 05/24/2009 - 15:00
Many thanks for the reply.Will do some digging on .178
Best regards,
Janesha
Leo Laohoo Sun, 05/24/2009 - 16:59
How desperate are you? New IOS will be coming out soon.
One thing to note though, no one has yet seen the new IOS so bugs and quirks are not readily known.
janesh_abey Sun, 05/24/2009 - 18:07
Hi Leo,
Thanks for the news.We are not that desperate but just need to get the 802.11n working.
On the topic of the new IOS hmmm..I tend to agree with the old saying "known devil is better the unknown angel" :)
BTW, whats the IOS you guys running?
Janesha
Leo Laohoo Sun, 05/24/2009 - 18:24
Hi Janesh,
We are running the 5.2.178.0.
If you are willing, you can load the 5.2.178.0 and when the new version arrives load that too. If you believe that the new version IOS is buggy then you can always tell the WiSM to load the backup IOS, which is 5.2.178.0.
Whatever your choice may be, make sure you also load the bootstrap image as well.
If you intend to use 802.11n, what model of the AP do you have in mind? The only 802.11n that requires the latest 5.1.X.X is the 1140 series. The 1250 can operate in the 4.X.X.X IOS.
Hope this helps.
Matthew Fowler Sun, 05/24/2009 - 19:34
Upgrading to 5.2 will also mean moving from LWAPP to CAPWAP, so keep in mind the ports change from UDP 12222/12223 to UDP 5246/5247.
janesh_abey Sun, 05/24/2009 - 19:47
Hi Matt,
Now that is something we completely forgot about!!!
Thanks heaps for the valuable info.
cheers,
janesha
