Multi-site setup with Point-to-Point and one UC500. Need remote side to use local gateway for 911 dialing.
Answered Question
May 23rd, 2009
I have one UC500 running CME 4.2 on my main location.  I currently have a Point-to-Point circuit between both sites and have phones working via both sites.  I am looking for a way to program the 1751-V router I have as a 911 gateway for my remote location only.  Currently I if I dial 911 from either location it uses the default FXO_Group and calls out from the main location.  This if fine when dialing 911 from the main but from my remote I need it to use the line here.  Any ideas would sure help.  Thank you in advance.
Correct Answer by Marcos Hernandez about 7 years 8 months ago
You will need CLI to accomplish this. On the UC500, you need to define a VoIP dial-peer that points to the 1700 site. The destination pattern needs to be "911" or "9911". Then, you need to increase the "preference" (selection order) of the POTS dial peers associated with your FXO trunks.
You can use the existing VoIP peers in place today as a reference to build the Emergency peer.
Here is an application note with more information about multisite deployments:
https://supportforums.cisco.com/docs/DOC-9652
I hope this helps,
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Overall Rating: 5 (1 ratings)
anthony.t Sun, 05/24/2009 - 11:56
As I look through this document it explains how to do a multi-site setup with multiple UC500's.  Do you know of any configuration examples that I can look at for the one UC500 and the 1700?  I do believe I am on the correct track.  Thank you.
Marcos Hernandez Mon, 05/25/2009 - 07:54
The VPN configuration between the two should be exactly the same. The voice piece should be very approximate, with only difference being voice ports and little more.
Marcos
Correct Answer
Marcos Hernandez Sun, 05/24/2009 - 09:56
I hope this helps,
Marcos Hernandez
Cisco Systems, Inc.
