May 23rd, 2009
HI all,
Error on initialize VLAN database 1: VTP feature not yet initialized[OK]
Anybody know what this error means.
Device running WS-C2950G-48-EI in Transparent VTP mode. Help me how can I solve this problem.
Thank You,
ramesh.karki Tue, 05/26/2009 - 07:32
I would too, but sometimes this switch is malfunctioning, even I could not log-in the switch. the buffer log shows :
*Sep 9 23:29:49.894 NST: %SYS-2-MALLOCFAIL: Memory allocation of 259644 bytes failed from 0x803B719C, alignment 0
Pool: Processor Free: 0 Cause: Not enough free memory
Alternate Pool: I/O Free: 136388 Cause: Not enough free memory
ramesh.karki Tue, 05/26/2009 - 09:11
Hi Andrew,
First time when I found this problem, it has been up since Sep 9.
Exactily sometimes a reboot fixes all the problem and start works like a normal switch.
Leo Laohoo Tue, 05/26/2009 - 13:54
Hi Ramesh,
I think your VLAN database is corrupt.
1. Delete the vlan.dat file
2. Enter the VLAN Database again.
3. Exit to save a new database.
See if this helps.
