Redundant Router Call Manager Express with E1 line.
Answered Question
May 24th, 2009
Hi there,
I need to configure redundant CCME router with E1-PRI PSTN line. Cisco gives the way to workaround for FXO line but no recommandation for E1 line.
With FXO line, Cisco suggest using splitter connected to the 2 redundant routers. Is there a splitter for E1 line ?
Also, hox can I ensure that confiration made on the active CCME router will be automatically duplicated on the redudant router ?
Thanks in advance.
Correct Answer by Rob Huffman about 7 years 10 months ago
Hi Tsilavo,
The best info I have ever seen on this question is from CME guru Tony @ Cisco;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Expert%20Archive&topic=Voice%20and%20Video&topicID=.ee7f996&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc2b092/36#selected_message
The problem with E1 PRI lines is that they will not be able to be functional on both routers at the same time (due to the D-Channel negotiation constricts). You can modifiy the connecting cable into a Y-type connection with one of the E1 interfaces shut down and only enabled during a "failover" time frame. This, of course, will require manual intervention :) The other consideration is that there is no "replication" of changes between the redundant routers, so any change made to router #1 will need to be manually configured on router #2.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Sun, 05/24/2009 - 08:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Tsilavo,
Hope this helps!
Rob
tranarison Sun, 05/24/2009 - 09:01
Thank you Rob.
It confirms my doubt.
Thanks.
I rated you.
Rob Huffman Sun, 05/24/2009 - 09:16
  • Hall of Fame,
    Founding Member
Hi Tsilavo,
You are most welcome my friend!
Cheers!
Rob
