BGP established state
May 24th, 2009
One of the wan routers had connectivity issues.While verifying, there was an event found a day back.
%BGP-5-ADJCHANGE: neighbor X.X.X.X Down Peer closed the session
But check on bgp neigbor status says
BGP state = Established, up for 6d08h.
1.What does first log mean & how to troubleshoot it?
2.Why does the recent event does get on the bgp state, it still shows up for 6 days and 8 hours whereas log shows an event recently.
Please suggest.
Thanks.
Giuseppe Larosa Mon, 05/25/2009 - 02:17
  • Hall of Fame,
    Founding Member
Hello Sunny,
this looks like strange.
Unless some soft-configuration has been used the first message should be the trace of having received a BGP notification message that should lead to session down.
The neighbor didn't like a message received from you and so it sended a BGP notification message.
Probably soft-reconfiguration made the BGP session to be up again with a single exchange of messages (your router could have holded the BGP prefixes for the neighbor as a result of soft inbound)
see
http://www.cisco.com/en/US/docs/ios/12_1/iproute/command/reference/1rdbgp.html#wp1020388
Hope to help
Giuseppe
