Double-ring for outside calls on VG224 SCCP analog phone
Overall Rating: 3.5 (2 ratings)
Rob Huffman Sun, 05/24/2009 - 09:21
Hi Michael,
I have checked every VG224 doc that I can find and it doesn't look like Distinctive Ringing is supported :(
Check out the Supplementary Services;
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_data_sheet09186a00801d87f6.html
Hope this helps! It's a bummer
Rob
PS: I have worked with some other NetPros who could not enable this feature with the VG224 :(
giftonabel Tue, 12/01/2009 - 00:31
You can have this feature activated by changing the required cptone, eg cptone IN, you can upgrade the VG224 IOS to vg224-i6s-mz.150-1.M.bin
or you can apply the command " ring cadence external " on the voice-port.
rgds,
Gifton
