CUPS not work
May 24th, 2009
I have a CUCM 6.1 and CUPS 6.0 environment.
After upgrade the CUCM to the version 7.0, the CUPS has stopped working (can not start the service Sync Agent).
When I run Troubleshooter in CUPS, the test "Verify reachability of publisher address, login and execute basic query", show me "Updated version of the CallManager" and request to restart the Sync Agent Service, but this service can not be started.
I do not reboot the CUPS after the CUCM upgrade.
Is there a procedure to run in CUPS after the CUCM upgrade?
Tks,
Ronaldo Gama
Rob Huffman Sun, 05/24/2009 - 08:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ronaldo,
Sadly, CUPS 6.x is not supported for use with CUCM 7.x, so you will require an upgrade to CUPS 7;
Table 3 Supported Cisco Unified Presence Upgrades for Release 1.0(1) through Release 6.0(4)
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/7_0/english/compatibility/cupcompatibility.html
Hope this helps!
Rob
