"configure replace" command failure
May 24th, 2009
Hello everybody,
In order to change large portions of my running-config without restarting my router, I tried to perform the command "configure replace nvram:my-special-conf"
It worked well with a Cisco 3845 router - IOS image: c3845-advipservicesk9-mz.124-15.T.bin
But it didn't with two of 7206 VXR routers with their respective images:
- Cisco 7206 VXR - IOS image: c7200p-spservicesk9-mz.124-4.XD7.bin
- Cisco 7206 VXR - IOS image: c7200-k91p-mz.122-25.S14.bin
Here is the output :
Router7200#config replace nvram:special-config
This will apply all necessary additions and deletions
to replace the current running configuration with the
contents of the specified configuration file, which is
assumed to be a complete configuration, not a partial
configuration. Enter Y if you are sure you want to proceed. ? [no]: Y
Error: could not write to output buffer incremental-temp.cfg
Rollback aborted after 1 passes
Router7200#
I neither found something about this error in the configuration guide (http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtrollbk.html), nor in google.
Did anyone know what is the problem and how to solve it ?
Thanks.
Overall Rating: 5 (1 ratings)
jimmysands73_2 Sun, 05/24/2009 - 07:23
  • Silver, 250 points or more
I have never used or even ever seen this command (but love learning new stuff!), I searched the web and found this:
http://www.nil.si/ipcorner/ConfigReplacement/
When faced with IOS configuration that cannot be changed (for example, the IP Service Level Agreement - SLA - configuration in Table 3), configuration rollback fares a lot better. It aborts the rollback process after five passes and gives you the list of commands it has attempted to execute in the last pass (Listing 6). You can then use the command list to fix the remaining configuration changes manually.
You can also go to page 91 of:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/prod_presentation0900aecd805456f7.pdf
HTH,
Jimmy
I searched Google for:
"rollback aborted" cisco
Leo Laohoo Sun, 05/24/2009 - 14:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Nice topic. +5 Jimmy
mchemsi28 Mon, 05/25/2009 - 02:11
Thank you Jimmy for your response.
Unfortunately it's not a problem of "unremovable IOS commands" like SLA: the sole difference between my running-conf and special-conf is "shutdown" and "rate-limit" interface-mode commands used to change commited access rate (a configured bandwidth) of an interface.
Besides, these changes worked well on my 3845 router.
I continue to investigate.
Chemsi
