05-24-2009 06:22 PM - edited 03-15-2019 06:10 PM
Hi experts,
2 of our users have asked to block specific external numbers to go to their specific extension/s.
Is this possible on CM 4.1(3)? How?
tia
05-24-2009 08:00 PM
There are PLENTY of posts on blocking calls, please try the search NetPro function
This is ONLY possible with H323, if you use MGCP there is no way to do this. CCM/CUCM version is irrelevant for the procedure
This blocks ALL calls from those numbers, there is no way to block them only when they dialed to someone in specific
Reject Calls
Call Blocking Configuration Examples
java
if this helps, please rate
05-24-2009 10:41 PM
We have development a software product for block external number which running on a seperate linux server. you can contact me by email lxiao.g@gmail.com.
Our customer same as your customer, and use same version CM 4.1(3). and use MGCP Voice Gateway.
Our product has a web base configure UI customer can configure want to blocked numbers to protect theirself IP Phone. and system administrator can configure global block numbers for all IP Phones.
And the key point that our product don't care the Voice Gateway using h.323 or MGCP.
