ACS 4.2 and 4096 bit certificate
Answered Question
May 25th, 2009
Hi there
is it possible to use an ACS and a CA Server with 4096 bit certificates?
Until now we tested with selfsigned 1024 bit certificates. Now I am not sure, I we can install a 4096 bit certificate on the ACS and if it can handle 4096 bit client certificates?
Thanks in advance.
Dominic
Correct Answer by Jagdeep Gambhir about 8 years 2 months ago
Dominic,
You can use 4096 bit certificate from ACS 4.2.0.124 patch 10 onwards.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Mon, 05/25/2009 - 06:35
  • Red, 2250 points or more
Dominic,
~JG
