05-25-2009 01:25 AM - edited 03-14-2019 04:08 AM
In an IPCC enterprise duplex scenerio one Call Router, side B went out of service but not did not take over by Router side A. Total CC operation was down due to one Call Router failure.
Can anybody help me to find out the reason?
Best Regards,
Muzammel
05-25-2009 05:03 AM
The most common reason is that the configuration is incorrect. Do a registry compare between the two routers. Another possibility might be an incorrect hosts file.
david
05-25-2009 09:52 AM
You need to test this tonight as soon as the contact center closes. Stop router A and make sure the system runs correctly using router B. Then restart router A, stop router B and make sure the system runs correctly using router A. When both routers are running, run rttest and ensure they are synchronizing.
Geoff
05-28-2009 01:54 AM
Thanks for the reply. May be I have identified the cause of Router failure. We have duplex side and at 17:31, Router-B was hanged and stoped sending heartbeat to Router side A. So Router A went simplex mode and processed call but due to poor response time with Router-A and PG-A, Total Contact center was not functioned properly.
But still i have another confusion; during that time some calls was successful and some were not. we have total of 5 DN. during router B outage 4 DN was partially worked but another DN was not worked at all.
can you please explain the reason.
see the logs for more details.
Muzammel
05-28-2009 04:32 AM
Can you verify that at one point all DNs were working? Is it possible that these DNs were added while there was an outage and the logger/router was not updated with the new config?
david
05-30-2009 10:13 PM
Hi David,
This Contact Center is running since two years and no new DN configured before Router outage.
Muzammel
