CME 4.1 Shared line can't be use for DSS
May 25th, 2009
Hi Guys
I have a secretary who is unable to use the shared line (her boss) configured on her 7th button to transfer call. DSS has been configured in the system, and it works for all other users except her.
I tried changing the button to monitor button, and it works. Strange enough is DSS works on other phones' shared lines, just not hers. I have also reset her phone through system, and also physically plugged out.
Her boss config:
ephone-dn 1 dual-line
number 720608
pickup-group 7201
label CS Chew (1)
description 6496-0608
name CS Chew
call-forward max-length 9
call-forward busy A720608
call-forward noan 729999 timeout 10
huntstop channel
hold-alert 60 originator
Secretary config:
ephone-dn 28 dual-line
number 720611
pickup-group 7201
label Karen Kam (1)
description 6496-0611
name Karen Kam
call-forward busy A720611
call-forward noan 729999 timeout 18
huntstop channel
ephone 28
ephone-template 1
username "karkam" password password
mac-address 001B.D47D.2002
speed-dial 1 720612 label "Lynn"
speed-dial 2 720614 label "Evelyn"
speed-dial 3 720636 label "Raha"
speed-dial 4 720615 label "Pam"
speed-dial 5 90161396031312 label "Marissa"
type 7961GE addon 1 7914
keep-conference endcall
button 1:28 2:77 4:116 6o206,207,208,209,210,211
button 7:1 8:50 9m3 10m12 <button 7 dss not working
Any advice is appreciated.
Rob Huffman Mon, 05/25/2009 - 04:17
Hi Esther,
I'm a little unsure about this comment;
"I tried changing the button to monitor button, and it works."
As one of the requirements for the use of DSS is the "Monitor" configuration, so it seems to be working as designed.
Have a look at this reference;
DSS (Direct Station Select) Service
In Cisco Unified CME 4.0(2) and later versions, the DSS (Direct Station Select) Service feature allows the phone user to press a single speed-dial line button to transfer an incoming call when the call is in the connected state. This feature is supported on all phones on which **monitor line buttons for speed dial or speed-dial line buttons are configured.
When the DSS service is enabled, the system automatically generates a simulated transfer key event when needed, eliminating the requirement for the phone user to press the Transfer button.
Disabling the service changes the behavior of the speed-dial line button on all IP phones so that a user pressing a speed-dial button in the middle of a connected call will play out the speed-dial digits into the call without transferring the call. When DSS service is disabled, the phone user must first press Transfer and then press the monitor or speed-dial line button to transfer the incoming call.
SCCP: Enabling DSS Service
To enable DSS Service for all on all SCCP phones on which monitor line buttons for speed dial or speed-dial line buttons are configured, perform the following steps.
Prerequisites
Cisco Unified CME 4.0(2) or a later version.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. service dss
5. end
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmespeed.html#wp1035362
Hope this helps!
Rob
esther.tan Mon, 05/25/2009 - 17:35
Hi Rob
I know it will work on Monitor button. We have users who is using this feature on shared line meaning the configuration is eg. 1:10 instead of 1m10. Get me?
This works for any other users, except one.
