05-25-2009 05:04 AM - edited 03-10-2019 04:38 AM
Hi All,
I am using DHCP in my network. And i need to reserve one IP for the Management Interface of the IPS.
I tried to get the MAC but couldn't. It is not even on the Show tech-support.
Can any please tell me how to get the MAC of Management interface of IPS?
Solved! Go to Solution.
05-25-2009 06:32 AM
If the show interface output is not giving you this information, you can logon via service account and run the 'ifconfig -a' command. Just make sure you do a 'su -' otherwise this command won't be available.
Please rate if helpful :)
Farrukh
05-25-2009 06:32 AM
Farrukh
05-25-2009 06:59 AM
Thank you Farrukh.
I appreciate your quick response. It was really helpful..
05-27-2009 12:42 AM
Btw, this information is available via the "show statistics host" command.
Farrukh
