Cisco Secure Services : config path
May 25th, 2009
I'm about to deploy Cisco SSC for a wired 802.1x solution.
I am not happy with the configuration path of the configuration.xml file that is by default on c:\Documents and Settings\All Users\Application data\Cisco\Cisco Secure Services Client\system\configuration.xml.
I didn't find a way to modify this path, neither with the SSC packager neither with regedit.
Is someone aware of a trick to modify this path ?
Thanks a lot
vmoopeung Mon, 06/01/2009 - 14:04
  • Bronze, 100 points or more
source directory or -s directory-specifies the source directory path. If the source directory option is not specified, the default value for the source directory is C:\Program Files\
Cisco Systems\Cisco Secure Services Client\profiles.
--quiet or -q-do not display the results
--help-gives the usage of the tool
