RTMT with incorrect statistic
Answered Question
May 25th, 2009
Hello
I have a little problem with our CM 4.1(3)sr8a, OS 2000.2.7 with Upgrade to 2000.4.5a and OS Service Release 2000.4.5bSR5.
I like to monitor the number of registered phones, cpu usage, memory usage etc. with the RTMT.
I don't know why, but it doesn't work anymore.
I get 0 registered phones, 100% memory usage etc. but this information can't be right.
Every idea is welcome. Thanks
Pascal
Correct Answer by Rob Huffman about 8 years 5 days ago
Hi Pascal,
When you upgraded to 4.1(3)sr8a did you install the "new" RTMT Plugin?
If any of the Client Plugins have a lower version than those included in this SR, perform the following:
After you have rebooted the server and completed the upgrade on all servers in the cluster, go to Cisco Unified CallManager Administration on any client machines (i.e. JTAPI, RTMT Client, etc.), navigate to the Application > Install Plugins menu. Choose the applicable plug-in, run the program from its current location, and follow the installation instructions that the system displays.
http://www.cisco.com/web/software/282074220/23393/ciscocm.4-1-3-sr8a-Readme.pdf
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 05/25/2009 - 06:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Pascal,
Hope this helps!
Rob
pblumenthal Thu, 05/28/2009 - 02:39
Hi Rob
I did this installation of the new RTMT version and after a reboot of our CM yesterday, it works fine now.
Thanks for your help.
Pascal
