05-25-2009 07:25 AM - edited 03-04-2019 04:52 AM
Hi All,
I am connecting two sites with Dialup Modems (Paradyne 3810).
Configuration of the two sites are following;
SITE A:
#interface serial0/0
#ip address 172.28.xx.xx 255.255.255.252
#no shutdown
Got the following error on A site
______________________________________
Serial0/0/0 is up, line protocol is down
Hardware is GT96K Serial
Internet address is 172.28.xx.xx/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output 00:00:16, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/4/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
473 packets output, 15896 bytes, 0 underruns
0 output errors, 0 collisions, 198 interface resets
10 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
SITE B:
#interface serial2/1
#no shutdown
On Site B, i get the error Serial 2/1 is up, line protocol is down.
________________________________________
Serial2/1 is up, line protocol is down
Hardware is M4T
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Last input never, output 05:58:57, output hang never
Last clearing of "show interface" counters 10w4d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1660
Output queue: 16/1000/64/1660 (size/max total/threshold/drops)
Conversations 1/4/256 (active/max active/max total)
Available Bandwidth 1536 kilobits/sec
59 packets output, 4927 bytes, 0 underruns
0 output errors, 0 collisions, 29 interface resets
44 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up
When i "shut" and "no shut" the interface, the SERAIL 2/1 IS UP FOR ABOUT 10 SECONDS AND AGAIN DOWN.
Kindly suggest where could be the problem; circuit or cable (connected to serial) or protocol.
Please also mention how to resolve it by some additional configuration if required.
05-25-2009 07:37 AM
Abdul
It is quite probable that the immediate cause of the problem is that the interface is configured with protocol HDLC and that the HDLC keepalives are not getting through. It is not so clear what is preventing the HDLC keepalives but I suspect that it is something with the Paradyne 3810 modem. The serial interface is not configured with anything about dialup, so am I correct to assume that all of the dial up parameters are configured on the Paradyne 3810? Can you check on the Paradyne 3810 and see whether there is some problem with it? Is it attempting to dial? Is the dial connection being completed?
Rick
05-25-2009 09:37 AM
Are the calls being completed/negotiated correctly?
05-25-2009 09:44 AM
Dialup modem with synch interfaces?
That is usually a recipe for failure.
Get ADSL on the sites, and do VPN. Or GSM dta service. Or get ISDN. Anything less isn't even worth the effort these days.
05-26-2009 06:06 AM
Try to Shut down the interface from one side and then DIAL - UP - connect the modems and then NO shut to check .
for further trouble shooting try to reduce the MTU size .
Further more - If you can find any thing in the log after 10 sec when the link goes down - it might be helpful.
05-26-2009 07:51 AM
Nauman,
It is taking the Default MTU now. and i tried to shut and no shut the interface 4,5 times but it use to get up for some time and than again down.
Kindly tell me some troubleshooting (debugging) commands sequence. I'll log the session and will paste it here for further support if required.
Rick,
Kindly note that the Modems are configured with default parameters. I just configured the Phone numbers which needed to be dialed.
So please tell me(the specific commands) if any thing needed to be added at the modems or router interfaces.
Waiting for reply....
