GW / GK On 2811
May 25th, 2009
We have 30 Branches, in HO we have one 2811 Router with 4 FXS & FXO. FXO is connected to the PBX (1..) & FXS is connected to FAX. this router is acting as the gatekeeper for other branch Routers. When I call on the FXS Port it rings & I can speak but when I call on the PBX Extension it gives a busy tone. If somebody has GK/GW Scenario in one router pl help.
gogasca Tue, 05/26/2009 - 00:07
  • Green, 3000 points or more
so u mean
from fxs to pbx works?
from pbx to fxs fail?
what is the configuration from pbx to fxs?
pbx -- fxo -- gw/gk -- dial-peer incoming pots and outgoing pots to fxs?
haarisalibaig Tue, 05/26/2009 - 02:07
On FXS Fax is connected & it works.
From the other branche somebody calls on our fax it works but PBX extension doesnot work.
The Scenario which is not working it
GW----GK----FXO
In my case at HO GW/GK is one 2811 router only.
I have attached the diagram for better understanding.
