Broken RTP stream from IP Cameras via IPSEC or GRE Tunnel
May 25th, 2009
I am experiencing very strange behavior of RTP stream from IP cameras (different vendors - D-LINK [cheap] and AXIS [expensive]).
I can get a video from camera in to ways.
1. MJPEG Stream - I use these type of links in Safari or FireFox:
http://admin:[email protected]/video/mjpg.cgi !!!TCP
or !!!TCP
And this is working excellent. The Picture is great. But it consumes a lot of expensive traffic.
2. MPEG4 stream - I use these types of urls in VLC, QuickTime or RealPLayer:
rtsp:// !!!UDP
rtsp:// !!!UDP
Sometime (very seldom and the picture is very unstable) I have a picture and sound, more often I do not see any picture but I hear broken sound.
At the same time the smae MPEG4 stream (rtsp://192.168.x.x:554) is working perfect if I am getting it from local lan PCs (where camera resides). But i have troubles with it outside local LAN (via tunnels).
Here is my net schema:
CAMERA - CAT2950 - C2811-IPSEC VTY via Internet (10 Mbits/s)-C3845-PIX-CAT3750-PC (VLC, QuickTime, RealPlayer)
CAMERA - CAT2960 - C1751V-GRE Tunnel via Internet (10 Mbits/s)-C2621XM-CAT2950-MAC (VLC, QuickTime, RealPlayer).
Also I have very similar schemas - but in all cases RTP is not working.
Something is going wrong with UDP packets during GRE/IPSEC encapsulation. But I do not know what. Please Help.
Thank you.
P.S. here is sample tunnel config, the are all similar :
interface Tunnel80
description IPsec to TOM via Comstar
bandwidth 2000
ip address
qos pre-classify
tunnel source 89.175.xx.xx
tunnel destination 77.236.xx.xx
tunnel mode ipsec ipv4
tunnel protection ipsec profile KM4
interface Tunnel55
description GRE to SKL via Comstar
bandwidth 10000
ip address
qos pre-classify
keepalive 3 3
tunnel destination 213.33.xx.xx
Mike Schooley Thu, 03/08/2012 - 08:17
did you get an answer, I'm going to guess fragmentation, but would like to know if you resolved.
