FAC not showing in Conference calls
May 25th, 2009
I am using CM5.1.3. FAC codes are not shown in Conference calls other than the first one in CDR. Any way by which these calls can be billed to the conference initiator.
Thanks in advance.
Jaime Valencia Mon, 05/25/2009 - 09:07
ad-hoc? meet-me?
What is the process you use for the conference?
if this helps, please rate
kolkatagtc Mon, 05/25/2009 - 09:11
User A dials User B
User A dials User C and does a conference.
User A dials User D and includes in conference.
fac is used for every call made in the conference.
Ideally it should show all the calls with the code used by User A but nothing is reflected in CDR.
Jaime Valencia Mon, 05/25/2009 - 09:46
OK, so if i understand correctly you only see FAC for A call B. right?
You should see it for the direct call from A to C, but not when C joins the conference as that is other call leg in which FAC has nothing to do.
