***********************Calls rejected************************
May 25th, 2009
Hi Pros
The following dial-peer keeps rejected all the calls- I means I got busy tone:
dial-peer voice 86008 voip
description -- send to OpenSER
translation-profile outgoing voip_toll_range_204
huntstop
destination-pattern 40345088..$
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
playout-delay nominal 250
playout-delay mode fixed
ip qos dscp cs5 media
no vad
We use this dial-peer for GrandStream analog adapter. My sip server shows that the phone 8843 is resgistred with the server and downloaded the proper firmare. However, my PRI GW keep denis the calls. There an ouput from the PRI GW
Time elapsed since last clearing of voice call statistics never
Connect Time = 3303358, Charged Units = 0,
Successful Calls = 4, Failed Calls = 71, Incomplete Calls = 0
Accepted Calls = 64, Refused Calls = 0,
Last Disconnect Cause is "39 ",
Last Disconnect Text is "bearer capability not authorized (57)",
Last Setup Time = -1512913577.
: 4034508843 Digits: 11
I called my PSTN service provider, they said that they send us the call and our PRI denies it.
Any ideas why the PRI denies these calls?
Thanks in advance,
Crazy
paolo bevilacqua Mon, 05/25/2009 - 10:45
  • Hall of Fame,
    Founding Member
To know, take debug isdn q931 and debug ccsip message with term mon.
CrazyDonJuan Mon, 05/25/2009 - 11:04
I enable debug isdn q931 and debug ccsip all then I called the number; however, there is no debuging message. And of course, type terminal monitor since I telnet to the device.
paolo bevilacqua Mon, 05/25/2009 - 11:06
  • Hall of Fame,
    Founding Member
Check "show log", level logging to console can have been changed.
