****************Dial-peer keeps denying calls*****************************
May 25th, 2009
Hi Pros
The following dial-peer keeps rejected all the calls- I means I got busy tone:
dial-peer voice 86008 voip
description -- send to OpenSER
translation-profile outgoing voip_toll_range_204
huntstop
destination-pattern 40345088..$
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
playout-delay nominal 250
playout-delay mode fixed
ip qos dscp cs5 media
no vad
We use this dial-peer for GrandStream analog adapter. My sip server shows that the phone 8843 is resgistred with the server and downloaded the proper firmare. However, my PRI GW keep denis the calls. There an ouput from the PRI GW
Time elapsed since last clearing of voice call statistics never
Connect Time = 3303358, Charged Units = 0,
Successful Calls = 4, Failed Calls = 71, Incomplete Calls = 0
Accepted Calls = 64, Refused Calls = 0,
Last Disconnect Cause is "39 ",
Last Disconnect Text is "bearer capability not authorized (57)",
Last Setup Time = -1512913577.
: 4034508843 Digits: 11
I called my PSTN service provider, they said that they send us the call and our PRI denies it.
Any ideas why the PRI denies these calls?
Thanks in advance,
Crazy
Dennis Mink Tue, 05/26/2009 - 20:56
what output do you get when you debug isdn q931
and does your dialpeer 86008 get hit at all?
(debug voip dialpeer all).
CrazyDonJuan Wed, 05/27/2009 - 07:04
Show isdn q931 did not give me any output and the dial-peer does get hit because everytime i make a test call, the failed called increase of 1. But I still got Last disconnected cause=39.
Moved the dial-peer without any change at all to a different PRI GW and asked the PSTN service provider to point the number to the new PRI gateway. Everything works fine with the new PRI.
CrazyDonJuan Wed, 05/27/2009 - 07:09
Sorry forgot to include in the previous post that I still need to find out why the previous get does not accept any call from this number. The PRI GW works fine for number and this is the first time I have issue with this gw.
I am considering the move over as a fix! I dont want to move all non-working number to another PRI. Really want to know what might wrong with this GW.
Thanks for any help.
Wes Schochet Thu, 06/11/2009 - 11:37
Can we see the T1 controller, d-channel and voice port config for both spans?
