paolo bevilacqua Mon, 05/25/2009 - 10:41
  • Hall of Fame,
    Founding Member
Yes, it does. It's called CUE AA.
Walter Solano Wed, 06/03/2009 - 16:35
  • Gold, 750 points or more
Yes there is an Auto Attendant that you can use.
You can configure it using the CLI or since you are not expert on this, you can use the CCA
