Does LMS3.1 supports VLAN Id greater than 1024?
Answered Question
May 25th, 2009
My customer wants to use VLAN IDs greater than 1024 and will use LMS 3.1.
On the docs, some VLAN Campus applications limit the VLAN Id to 1024. What is the max. VLAN Id supported by the Campus Apps. and CiscoView on LMS 3.1?
Correct Answer by Joe Clarke about 7 years 12 months ago
Yes, Campus can support VLANs up to 4096 (with 1002-1024 and 4095 as reserved) depending on whether or not the device can support such VLANs.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 05/25/2009 - 14:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
rgomes Tue, 05/26/2009 - 06:13
Thanks. I suggest to correct the CM documentation, help file included, under chapter Creating VLANs to reflect the true support. On other places on the docs there is no restriction stated.
Joe Clarke Tue, 05/26/2009 - 08:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yep, I already filed CSCsz82090 to get the help corrected.
