robert.bernal Mon, 05/25/2009 - 14:45
OK, Done. I just filled the deployment location settings.
Thanks.
Tomas De Leon Wed, 07/01/2009 - 05:18
  • Cisco Employee,
The first clue is the error itself. Check to see that you have configured
the "DEPLOYMENT LOCATION" settings in the Video Portal-> Setup -> Deploy Locations
admin page.
The publishing location for all content should be an external
media server of some sort as documented here:
http://www.cisco.com/en/US/docs/video/digital_media_systems/5_x/5_0/dmm/user/guide/crconoff.html#wp1104317
Although it's true that you can push content to the video portal (usually for demos)
hosting the content on the Video Portal itself is NOT a Recommended or
TAC Supported Solution. With that said, the SFTP username is 'vpsftp' for
the video portal and the password is the same as the AAI password for
the 'admin' user.
"For DEMO purposes only:"
Here's a sample of directory configuration that is often
used in demos. Please note that the directory 'cisco'
is the Video Portal "Instance name" and can be changed
to match your specific instance:
Root URL File Directories are as follows
Flash
/dm2/www/html/cisco/dms/video_portal/media/flash
Windows
/dm2/www/html/cisco/dms/video_portal/media/windows
MPEG4/H.264
/dm2/www/html/cisco/dms/video_portal/media/mpeg4
Real
/dm2/www/html/cisco/dms/video_portal/media/real
Support
/dm2/www/html/cisco/dms/video_portal/support
Root URL Path are as follows
Flash
http:///cisco/dms/video_portal/media/flash
Windows
http:///cisco/dms/video_portal/media/windows
MPEG4/H.264
http:///cisco/dms/video_portal/media/mpeg4
Real
http:///cisco/dms/video_portal/media/real
Support
http:///cisco/dms/video_portal/support
