**************Set number of the ring in fxs port**********************
May 25th, 2009
Hi Pros,
Can I set how many time a phone connected to a fxs has to ring?
I am trying to forward this number to a voicemail server. Eventhough I have a dial-peer to forward the call,but the FXS keeps ring.
For example, I want to forward the call to voicemail after 5 rings.
1. Have the remote router which the fxs card. Set the number on the port and a Dial-peer to send the call to the voice gw.
2. Voice gateway with 2 dial-peer with different preference number.First dial-peer send call to the remote router(lower preference number).Second dial-peer with higher pref number send the calls to the voicemail server.
My questions: How can I instruct the fxs card to send the call to voicemail?
There are the dial-peers
1.voice gw
a)
dial-peer voice 2013 voip
preference 1
destination-pattern 6046779391
session target ipv4:x.x.x(remote ID)
dtmf-relay h245-signal
ip qos dscp cs5 media
no vad
b)
dial-peer voice 20131 voip
preference 2
progress_ind setup enable 3
translate-outgoing calling 12
no translate-outgoing called 11
voice-class codec 2
session protocol sipv2
session target ipv4:x.x(voice server IP)
dtmf-relay rtp-nte
playout-delay nominal 250
playout-delay mode fixed
no vad
Remote router dial-peer
dial-peer voice 700 voip
preference 9
translate-outgoing calling 2
translate-outgoing called 2
session target ipv4:x(Voice gw IP)
dtmf-relay cisco-rtp
no vad
dial-peer voice 304 pots
max-conn 1
port 0/2/0
Hope i have enough info,
Thanks in advance,
Crazy
paolo bevilacqua Tue, 05/26/2009 - 07:29
  • Hall of Fame,
    Founding Member
Already replied in another thread, please do not post duplicates.
