UC520 Site-to-Site VPN
May 25th, 2009
Hi there,
We are trying to connect to UC520 devices to eachother with an site-to-site ipsec VPN. The one site has LAN range 192.168.2.x and the other site has LAN range 192.168.1.x We followed many articles but the result is that the tunnel will not get up and there is no traffic flow between both sites. Enclosed i have the configuration of the tunnels. What could be the problem ?
cisco24x7 Tue, 05/26/2009 - 03:22
Your issue, I think, has to do with NAT.
you need to disable NAT at both location,
something like this:
site A: access-list 100 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
ip nat inside source list 100 inteface F0/0 overload
site B: access-list 100 deny ip192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
once you've done that, do "clear ip nat trans *" and try again. It will work this time. The purpose of access-list 100 is to tell both site A and site B, when communicating with each other, do NOT NAT,
mamkreutz01 Tue, 05/26/2009 - 11:07
Thanks for the reply. I put the extra lines in the configuration but the tunnel is not coming up at all. When i do sh crypto isakmp sa the device shows me nothing and when i do sh crypto ipsec sa there is no connectivity. What could be the problem ?
