PIX 515e connection not stable
May 25th, 2009
PIX 515e with 8.0(4) IOS /24 network configured from INSIDE network and another 2 interfaces or configured. From INSIDE network i am able to establish connection only from some of the PCs and other PCs or not connecting this is intermident sonme PCs which are connecting sometimes not connecting and some PCs which are not connecting sometimes connects. This for the destination through both the other interfaces. Please let me know if any one of you faced similar type of issues and the solution for the same.
smalkeric Mon, 06/01/2009 - 08:27
The problem might be with the IP pool assignment either through ASA/PIX or Radius server. Use the debug crypto command in order to verify that the netmask and IP addresses are correct. Also, verify that the pool does not include the network address and the broadcast address. Radius servers must be able to assign the proper IP addresses to the clients.
