ACE - Weight
Answered Question
May 26th, 2009
i have a Serverfarm with 2 Real Servers configured with RoundRobin Load-Balancing.
Now i want the traffic distributed to the same rserver all the time, except the probe failed.
Can i just turn up the weight to 100 for one rserver to stick the traffic to it?
Correct Answer by ciscocsoc about 7 years 9 months ago
No.
You either need to define a backup rserver in your serverfarm:
serverfarm host FARM-sql1-Mirror
description SQL Serverfarm Mirror
probe PROBE-sql
rserver sql1-Mirror
backup-rserver sql1-Node2
inservice
rserver sql1-Node2
inservice standby
or define two serverfarms - one server in each and then use one as a backup serverfarm:
serverfarm host FARM-web2-Master
probe PROBE-web2
rserver cc250-master
inservice
serverfarm host FARM-web2-Slave
probe PROBE-web2
rserver cc250-slave
inservice
policy-map type loadbalance first-match LB-POLICY
class class-default
serverfarm FARM-web2-Master backup FARM-web2-Slave
Which you choose is down to personal preference and if you need to be able to use more than one server in future.
Cathy
Overall Rating: 5 (1 ratings)
Correct Answer
ciscocsoc Tue, 05/26/2009 - 01:39
No.
probe PROBE-sql
rserver sql1-Mirror
inservice
rserver sql1-Node2
inservice standby
probe PROBE-web2
inservice
probe PROBE-web2
rserver cc250-slave
inservice
class class-default
Cathy
