switch 2960G-24TC-L
May 26th, 2009
Hello
i have switch 2960G-24TC-L when i'm insert 1000BASE-SX module to the port Giga 0/23
and i can't see the LED go to green on this port , and when i run command
# show inventory
doesn't see the fiber module ,
only see 2960G-24TC-L
what's problem maybe the module problem or must work thing on switch to work ,
and what i want work on switch to active this port on fiber and disable it on ethernet UTP
help me
Giuseppe Larosa Tue, 05/26/2009 - 04:53
  • Hall of Fame,
    Founding Member
Hello Mohamad,
try the following:
config term
int gi0/23
media-type sfp
to tell the switch you want to use the fiber based module and not the rj45
Hope to help
Giuseppe
engmohamad1980 Tue, 05/26/2009 - 06:26
thank you
i'm trying this command but no result.
and i'm insert FX module and execute
#show inventory
i'm notice the switch see the module .
when insert sx mdule the switch don't see anything
and i want ask if insert the module to switch the port led must be green ot flush or not ??
Giuseppe Larosa Tue, 05/26/2009 - 06:52
  • Hall of Fame,
    Founding Member
Hello Mohamad,
try also
conf t
int gi0/23
shut
no shut
the config guide lists only 100 Base X SFP
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_46_se/configuration/guide/swint.html#wp1028628
So I wonder if it supports a real GE fiber based port
It is supported starting from release 12.2(25)FX
see table 4 in the following
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp128965
Hope to help
Giuseppe
Leo Laohoo Tue, 05/26/2009 - 13:40
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Is the GLC-SX-MM from Cisco or is it from a third-party?
Is Interface Gig0/23 in error disable?
Is Interface Gig0/23 also being used by a copper line?
Have you tried to put this SFP somewhere else?
Have you tried other SFP?
engmohamad1980 Wed, 05/27/2009 - 06:10
hello
i'm discover the module have problem .
but i want know why the 100Fx module doesn't work fine ,
engmohamad1980 Wed, 05/27/2009 - 06:42
hello
