05-26-2009 04:09 AM - edited 02-21-2020 03:28 AM
I need of a client for remote access to use in my MAC and WINDOWDOS 64 BIT.
I have searched this, but I did understand that this client there is no for MAC and Win 64-bit just anyconnect has supported this.
Do you know if possible use anyconnect for remote acess vpn? If yes, how is made the anyconnect client configuration?
05-26-2009 05:47 AM
Anyconnect is the next generation of VPN Client, so yes, you can use it for remote access vpn. The client configuration is very easy. You enter the the hostname of the VPN, then when the VPN is established, you enter your username, password, and group (if necessary).
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080975e83.shtml
Hope that helps.
05-26-2009 06:10 AM
I did understand, but the problem is that we have one tunnel for remote access e other tunnerl for ssl vpn.
How use the anyconnect for permit connection in remote access tunnel?
05-26-2009 06:17 AM
AFAIK, Cisco is planning to integrate both the IPSEC and SSL clients into one, but till now both of them are separate.
So you cannot use Anyconnect for IPSEC connections.
Farrukh
