francisco_1 Tue, 05/26/2009 - 04:46
  • Gold, 750 points or more
I dont think so!
you will need to have a an optical port on your c2924 which it doesn't have.
scottmac Tue, 05/26/2009 - 05:15
  • Green, 3000 points or more
Probably not, even with a transceiver, because most transceivers are the same speed output as input.
What you need is a cheap switch with a 1000sx optical port and a/some 10/100/1000 ports (to act as a differential transceiver).
Part of the issue is the buffering needed for traffic coming from the 1000Mbps side to the 100Mbps side.
If you find one, let us know!
Good Luck
Scott
BrinksArgentina Tue, 05/26/2009 - 06:55
You can buy a 100FX SFP for your 3750. (U$S 200).
This way you keep a simple and clean setup.
Guido.
Please rate all the helpful comments.
Leo Laohoo Tue, 05/26/2009 - 13:44
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
It won't. GLC-SX-MM is a 1000Base and won't auto-negotiate to 100 mbps.
