Routing
Don't miss this Cisco Catalyst 8000 offer
Labels
Finding accurate answers to your questions and issues is always gratifying, but what if these answers are shared globally across different languages? The Cisco Community team has been working on a proof of concept (PoC) to take Accepted Solutions in...
Kelli Glass by Community Manager
  • 10007 Views
  • 7 replies
  • 16 Helpful votes
Greeting everyone! There is a little problem with configuring tacacs server on ws-2950-24 model switch. The rest switches we have are 2960 series, also 3xxx series and others, more modern versions. We always configured tacacs server this way:tacacs-s...
Hello Team,I'm facing a challenge to apply a patch on the Cisco ISR4331. See the below error message from the router. SIMBA-RT#install add file bootflash:isr4300_cpld_update_v2.0.SPA.bin activate commitinstall_add_activate_commit: START Wed Mar 27 11...
dissai by Level 1
  • 129 Views
  • 6 replies
1. Make end to end connectivity first. 2. Block the network for these site   1)Make sure that Site 4 will not advirtise any network to Site 5 which it receiving from Site3 routers.  2) On site 5 , when we check routing table of R2 router,  it dont ha...
Hello,I have very simple Cisco EVPN VxLAN fabric running on Cisco nexus 93180YC-EX switches. I am using OSFP + iBGP for underlay/overlay with Multicast. I have border-leaf switches connected to single ISP with eBGP peers and I am advertising my publi...
these routers are direclty connected via point to point connection.  When I try summarization, only ip route x.x.x.x x.x.x.x null0 with network statement works for me.  When I use the aggregate address command I dont see summary route in route table....
davinci by Level 1
  • 3771 Views
  • 6 replies
                                                         VRF LITEVRF Lite is a simplified version of VRF that uses only IP routing, while the full version of VRF can support multiple routing protocols like OSPF and BGP.VRFs are an essential component...
Gopinath_Pigili_0-1711559660914.png Gopinath_Pigili_1-1711560342503.png Gopinath_Pigili_5-1711561314609.png Gopinath_Pigili_4-1711561261838.png
I have recently taken over a site that utilizes a Cisco Router to act as their public facing device/firewall. I have been tasked with setting up a IKEv2 S2S tunnel with one of our external vendors, and it will need to be setup on this router.I have w...
IWSup by Level 1
  • 225 Views
  • 11 replies
I'm in a tough spot and currently having an issue with configuring a GRE over IPsec in my personal project. I think the configurations are right based on the verification commands that I used which are: show crypto isakmp sa and show crypto ipsec sa....
iskra by Level 1
  • 133 Views
  • 5 replies
Hello,We have to drop a new ASA behind an SDWAN box and I wanted to confirm a route that's giving me a hard time. There are 2 ISP connections to the SDWAN Device which is itself connected to the ASA Outside interface (let's say 6.6.6.6) with the Insi...
PJ123 by Level 1
  • 339 Views
  • 7 replies
Hallo,I would like to understand how to verify the active and standby routers in our network on the core switch. From the snippet below, HSRP is configured on the transfer VLAN 828 to the ISP. The 'sh standby brief' command is not on the NEXUS switch...
Joy3 by Level 1
  • 95 Views
  • 3 replies
