Debug in PIX
May 26th, 2009
Intially we used the PIX IOS 6.3 were we will use the command to debug some IP from outside and inside
example
debug packet inside src 10.180.1.1
debug packet ouside dst 80.1.X.X
but right now we upgraded the IOS to 7.2 how i can issue the same command to see the debug for the specfic ip
darkbeatzz Tue, 05/26/2009 - 07:42
use Capture.
Its a fantastic new tool introduced in 7.0
basically you create and acl
capture the acl
sh capture
ASA Capture Feature
The administrator needs to create an access-list that defines what traffic the ASA needs to capture. After the access-list is defined, the capture command incorporates the access-list and applies it to an interface.
ciscoasa(config)#access-list inside_test permit icmp any host 192.168.1.1
ciscoasa(config)#capture inside_interface access-list inside_test interface inside
The user pings the inside interface of the ASA (ping 192.168.1.1). This output is displayed.
ciscoasa#show capture inside_interface
1: 13:04:06.284897 192.168.1.50 > 192.168.1.1: icmp: echo request
!--- The user IP address is 192.168.1.50.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807c35e7.shtml
http://security-planet.de/2005/07/26/cisco-pix-capturing-traffic/
